Displaying items by tag: ea addin, script, query, navigate
Key features
- Import and export SysML requirements data from Excel into Enterprise Architect.
- Ability to create SysML Compliant requirements with inter-dependencies
- Requirements – The requirements sheet is used to create and update SysML compliant requirements, including Id and text, the sheet also displays any derived requirements (interconnected requirement)
- Requirement Matrix – This worksheet will present all requirements in a matrix format to let users easily create derivation inter-dependencies between them.
- This sheet will be automatically updated when new requirements are added in the ‘Requirements’ worksheet
- New relationships created in this spreadsheet will also be automatically updated in the ‘Requirements’ worksheet
To sync or update the modifications to the Enterprise Architect Model, use the Excel to EA icon. The changes reflected in the Enterprise Architect Model will be shown in the preview form. To update into an Enterprise Architect Model, select Export.
The EA to Excel icon is used to restore the produced items to their original state as in the Enterprise Architect Model.
Prior to ‘EA to Excel’
Post ‘EA to Excel’
Dropdown list to choose the Export to Enterprise Architect Model or the SysML Requirement Manager for the document. ‘Export to EA’: Export the elements to Enterprise Architect using Profiles ‘SysML Requirement Manager’: Import SysML Requirements from Enterprise Architect and Export SysML Requirements and their connections to Enterprise Architect. |
Allows one to select a *.eap or *.eapx or *.feap or *.qea or *.qeax or *.eadb through Local project, server Connection, or cloud connection. Local Project - To Connect Local Enterprise Architect model. Server Connection - To Connect to an Enterprise Architect repository through a database Cloud Connection - To Connect to an Enterprise Architect repository through Pro Cloud Server |
Select a package
- This screen will be displayed when the Package button is clicked.
- It displays all the models and packages from the selected Enterprise Architect model, with SysML Requirement items being imported specifically.
Toolset to set linestyle, quick search, search / service on button / keyboard and a lot more
Abstract:
A toolset to make every day life easier. The main functions are:
- Set line style in diagram by just a click
- Searches and services at Buttons / Keyboard keys
- Navigate by click
- Change Author
- Change *.xml file of a controlled package
- Create / update Activity diagram for an operation
- etc.
Description:
- Quickly set line style to selected Diagram, Elements and/or Connector
LV= Lateral Vertical
LH= Lateral Horizontal
TH= Tree Vertical
etc., see tooltip - Quick search for class, attribute, operation
- Navigate between structure and behavior
- Specification (Open the links of file properties, source code, *.xml file)
- Create Activities and Parameters for operations
- Searches and services on buttons and keyboard keys
- Sample Queries
- Sample scripts at your finger tip
- And a lot more to experience
Have a look at the help and give it a try.
Installation:
You get the newest release from:
https://dl.dropboxusercontent.com/u/66337741/ho_Tools/ho_Tools.zip
- Run ho_tools_Setup_V1.035.msi (delete old release first)
- Copy ho_ToolsTechnology.xml to c:\Programme\Sparx Systems\EA\MDGTechnologies\
- With EA:
Project,Import Reference Data, ... ho_Tools_Scripts.XML
