Displaying items by tag: sparx systems india
Wednesday, 17 May 2023 07:05
Key features
  • Import and export SysML requirements data from Excel into Enterprise Architect.
  • Ability to create SysML Compliant requirements with inter-dependencies
  1. Requirements – The requirements sheet is used to create and update SysML compliant requirements, including Id and text, the sheet also displays any derived requirements (interconnected requirement)
  1. Requirement Matrix – This worksheet will present all requirements in a matrix format to let users easily create derivation inter-dependencies between them.
  • This sheet will be automatically updated when new requirements are added in the ‘Requirements’ worksheet
  • New relationships created in this spreadsheet will also be automatically updated in the ‘Requirements’ worksheet
Excel_to_EA_icon.png To sync or update the modifications to the Enterprise Architect Model, use the Excel to EA icon. The changes reflected in the Enterprise Architect Model will be shown in the preview form. To update into an Enterprise Architect Model, select Export.
EA_to_Excel_icon.png The EA to Excel icon is used to restore the produced items to their original state as in the Enterprise Architect Model.
Prior to ‘EA to Excel’
Post ‘EA to Excel’
Dropdown list to choose the Export to Enterprise Architect Model or the SysML Requirement Manager for the document.
‘Export to EA’: Export the elements to Enterprise Architect using Profiles
‘SysML Requirement Manager’: Import SysML Requirements from Enterprise Architect
and Export SysML Requirements and their connections to Enterprise Architect.
Allows one to select a *.eap or *.eapx or *.feap or *.qea or *.qeax or *.eadb through Local project, server Connection, or cloud connection.
Local Project - To Connect Local Enterprise Architect model.
Server Connection - To Connect to an Enterprise Architect repository through a database
Cloud Connection - To Connect to an Enterprise Architect repository through Pro Cloud Server
Select a package
  • This screen will be displayed when the Package button is clicked.
  • It displays all the models and packages from the selected Enterprise Architect model, with SysML Requirement items being imported specifically.
Friday, 22 April 2022 14:30
The much-awaited Sparx Systems #EnterpriseArchitect 16.0 released!!!.
The world-leading modeling tool now with the cutting edge features to meet the emerging needs of remote, distributed teams. Auto-refresh diagrams, Auto-reloading in-flight diagrams, Excel-like views to edit artifacts and relationships, Custom dynamic documents, Faster
Model interchange. and a plethora of long-awaited enhancements to simplify and make modeling easier and efficient.
More information on key features can be found in the articles below
ENTERPRISE ARCHITECT 16.0 – A Quick Glance
https://sparxsystems.in/enterprise-architect-16-0-a-quick-glance/
https://sparxsystems.in/enhanced-user-security-in-enterprise-architect-16/
QEA Files in Sparx EA 16 enables EA SaaS solution
https://sparxsystems.in/qea-files-in-sparx-ea-16-enables-ea-saas-solution-for-individuals-and-small-teams/
Scriptlets in Enterprise Architect 16 – A Step Beyond Static View
https://sparxsystems.in/scriptlets-in-enterprise-architect-16-a-step-beyond-static-view/
https://sparxsystems.in/ultimate-sparx-enterprise-architect-16-user-guide/
Additional Resources
EA SaaS is now available for Small and Medium Teams, powered by QEA files
https://sparxsystems.in/enterprise-architect-saas/
EA SaaS for Small Teams (EA for Mac) Video  -  https://www.youtube.com/watch?v=MF0BdnasvqI
Visit https://sparxsystems.com/products/ea/16.0/index.html or reach This email address is being protected from spambots. You need JavaScript enabled to view it. for a demo.
Tuesday, 09 January 2018 05:22
Sparx Systems University Week - March 2-9, 2018
The first Sparx University Week for 2018 will be run during March, with most training sessions being held during the week of March 2-9.
University Weeks are hosted by Sparx Systems Japan, Sparx Systems Central Europe, Sparx Services North America, Sparx Systems India and Sparx Services UK (Hippo Software).
The delivery format for each course varies depending on the subject, audience and location, with a mix of both online and face-to-face seminars and courses.
It is anticipated that Sparx University Week will be run on a global basis every few months, in conjunction with Sparx Systems Sister and Services Partner network.
Bookings are essential, please review the course schedule below and visit the course provider's website for more details and to register your place.
Sparx University Week Schedule:
 Facilitator: Date/Time: Course Title: Location: Language: Link:
Sparx System Japan 2nd March 1:45pm - 5:25pm Tokyo Enterprise Architect Case Studies Seminar 2018 - Free Session! sign-up will be open on the 15th January
Tokyo International Forum (1 minute walk from JR Yurakucho Station) Japanese Details & Registration
Sparx Systems India 5th - 7th March 9:30am - 4:30pm IST Enterprise Architect Training & Workshop for SDLC using UML Online Delivery English Details & Registration
Sparx Systems India 8th - 9th March 9:30am - 4:30pm IST Enterprise Architect Training & Workshop for BA Online Delivery English Details & Registration
Sparx Services UK (Hippo Software) 5th-6th March 2018 (2 days) 10am - 4pm GMT EA and ArchiMate for Business Architecture Online Delivery English Details & Registration
Sparx Services UK (Hippo Software) 7th-8th March 2018 (2 days) 10am - 4pm GMT EA and ArchiMate for Enterprise Architecture Online Delivery English Details & Registration
Sparx Services North America 6th & 7th March 9 am - 5:30 pm CST Business Process Modelling with BPMN - 2day course Online Delivery English Details & Registration
Sparx Services North America 8th March 9 am - 5:30 pm CST Enterprise Architect Business Process Modelling Online Delivery English Details & Registration
Sparx Systems Central Europe 8. März 2018: 09:00-12:00 (MEZ) Webinar Sparx Pro Cloud | Installieren, Konfigurieren, Modellieren auf der Zeitachse und wiederverwendbare Bausteine und Standards Online Delivery Deutsch Details & Registration
Sparx Systems Central Europe 8th March 2018: 1p.m.-4p.m. (MEZ) Webinar Sparx Pro Cloud | Installation, Configuration, Time-Aware-Modelling and Reusable Asset Services Online Delivery English Details & Registration
Sparx Systems Central Europe 15.-16.02.2018 UML Grundlagen, 2 Tageskurs bei München München Deutsch Details & Registration
Sparx Systems Central Europe 08.-09.03.2018 Modellbasierte Entwicklung, 2 Tageskurs bei München München Deutsch Details & Registration
Sparx Systems Central Europe 13.-14.02.2018 SysML mit EA, 2 Tageskurs in München München Deutsch Details & Registration
Sparx Systems Central Europe 07.-08.03.2018 SysML mit EA, 2 Tageskurs in Wien in Wien Deutsch Details & Registration
Sparx Systems Central Europe 805.03.2018 9-12h00 MEZ Pro Cloud Installation u.v.m. 3 hours Online Delivery Deutsch Details & Registration
Sparx Systems Central Europe 10.04.-11.04.2018 Best Practice Days in Nürnberg Nürnberg Deutsch Details & Registration
Sparx Systems Central Europe 5-06.03.2018 UML Fundamentals Vienna, 2 days course Vienna English Details & Registration
Sparx Systems Central Europe 05.03.2018 13-16h00 CEST Pro Cloud Installation and more Online Delivery English Details & Registration
Published in Events
Monday, 18 September 2017 06:00
Sparx Systems University Week - 23-27 Oct, 2017
The second Sparx University Week will be run during October, with most training sessions being held during the week of October 23-27.
uni week 2 hi rct
Sparx Systems Central Europe Mon 16 Oct: 9:00am - 12:00pm CEST UML Fundamentals with Enterprise Architect - Free Session!  Online Delivery  English Details & Registration
Sparx Systems Central Europe Thur 19 - Fri 20 October Model-based Development with Enterprise Architect Nuremberg, Germany German Details & Registration
Sparx Systems Japan Fri 20 Oct: 1:30pm - 5:45pm JST
Enterprise Architect Introductory Seminar - Free Session!
Yokohama, Japan Japanese Details & Registration
Sparx Services UK (Hippo Software) Mon 23 - Tue 24 October Enterprise Architect, BPMN and Use Cases Online Delivery English Details & Registration
Sparx Systems Central Europe Mon 23 - Tue 24 October Enterprise Architect Foundations Munich, Germany German Details & Registration
Sparx Systems Central Europe Tue 24 - Wed 25 October SysML with Enterprise Architect Munich, Germany German Details & Registration
Sparx Systems Central Europe Tue 24 - Wed 25 October Enterprise Architect Foundations Zurich, Switzerland German Details & Registration
Sparx Systems Central Europe Tue 24 - Wed 25 October Enterprise Architect for Developers Amsterdam, Netherlands English Details & Registration
Sparx Systems Central Europe Tue 24 - Wed 25 October Enterprise Architect for Developers Vienna, Austria English Details & Registration
Sparx Systems North America Tue 24 - Thur 26 October BIZBOK® 4 Foundation with Enterprise Architect Online Delivery English Details & Registration
Sparx Systems India Tue 24 - Thur 26 October Enterprise Architect for Business Analysis Online Delivery English Details & Registration
Sparx Services UK (Hippo Software) Wed 25 - Thur 26 October Enterprise Architect and ArchMate  Online Delivery English Details & Registration
Sparx Systems Japan Fri 27 Oct: 1:30pm - 5:40pm JST Enterprise Architect Utilization Seminar - Free Session! Yokohama, Japan Japanese Details & Registration
Published in Events
