Displaying items by tag: sysml technology
Key features
- Import and export SysML requirements data from Excel into Enterprise Architect.
- Ability to create SysML Compliant requirements with inter-dependencies
- Requirements – The requirements sheet is used to create and update SysML compliant requirements, including Id and text, the sheet also displays any derived requirements (interconnected requirement)
- Requirement Matrix – This worksheet will present all requirements in a matrix format to let users easily create derivation inter-dependencies between them.
- This sheet will be automatically updated when new requirements are added in the ‘Requirements’ worksheet
- New relationships created in this spreadsheet will also be automatically updated in the ‘Requirements’ worksheet
To sync or update the modifications to the Enterprise Architect Model, use the Excel to EA icon. The changes reflected in the Enterprise Architect Model will be shown in the preview form. To update into an Enterprise Architect Model, select Export.
The EA to Excel icon is used to restore the produced items to their original state as in the Enterprise Architect Model.
Prior to ‘EA to Excel’
Post ‘EA to Excel’
Dropdown list to choose the Export to Enterprise Architect Model or the SysML Requirement Manager for the document. ‘Export to EA’: Export the elements to Enterprise Architect using Profiles ‘SysML Requirement Manager’: Import SysML Requirements from Enterprise Architect and Export SysML Requirements and their connections to Enterprise Architect. |
Allows one to select a *.eap or *.eapx or *.feap or *.qea or *.qeax or *.eadb through Local project, server Connection, or cloud connection. Local Project - To Connect Local Enterprise Architect model. Server Connection - To Connect to an Enterprise Architect repository through a database Cloud Connection - To Connect to an Enterprise Architect repository through Pro Cloud Server |
Select a package
- This screen will be displayed when the Package button is clicked.
- It displays all the models and packages from the selected Enterprise Architect model, with SysML Requirement items being imported specifically.
