Displaying items by tag: sparx enterprise architect 16 code analyzer
  • The Code Analyzer is a must-have tool when working with source code. It runs extremely complex queries on source code repositories at incredible speeds, when used locally or on a Sparx Intel cloud service.
  • The Code analyzer uses a high-level query language developed by Sparx systems. It also has a large vocabulary that allows code metrics to be queried quicker than traditional methods.
  • It is highly effective for large-scale code bases. This is because it allows the user to rigorously check any minor changes using a distinct cross-reference analysis of the code to verify that all effects are clearly visible.
Code Miner Framework
  • In Sparx Enterprise Architect 16, users can compile their code base into a Code Miner repository. Code Miner system provides instant and comprehensive access to existing source code information.
  • It enables complete access to all features of the original source code in a machine-readable manner. This is done by parsing all source code and storing the resulting “Abstract Syntax Tree” in a read-optimized database.
  • The main purpose of the Code miner is to give quick and effective access to data concealed within source code.
  • The interfaces have been designed to be as simple as possible while ensuring optimal performance.
  • As a result, the system can assess the program's structure, calculate metrics, track relationships, and even refactor the code.
Code_Miner_Framework
        Figure 1: Code Miner Framework
What’s New in Sparx Enterprise Architect 16?
Sparx Intel Service
  • The Sparx Intel service program enables development projects and customers to learn more about the code bases and software frameworks they're working with.
  • Multiple Enterprise Architect customers can use the service to access and (raise a query for the same data) query the same data from a variety of software domains and frameworks.
  • Clients of Enterprise Architect can use the service to have access to Intelli-sense in code editing and smart search results in search tools.
  • The Sparx Intel service is a division of Sparx Satellite Services. The service can be installed on a local network or in cloud, plus it runs on Microsoft Windows.
  • The Sparx Intel Satellite service can be executed as a standalone process or as a Windows service.
Sparx Intel Service
        Figure 2: Sparx Intel Service
Config File Format
Directive Description
Name When a service is named on the command line, the service with the matching name attribute will be commence.
Status The service will be start only when status = ON
Lazyload When lazyload is 'true', any Code Miner database will be delay loaded until an Intel request is made to the service.
Loglevel
Defines the level of information logged, as a combination of keywords { information, warning, error} separated by a '|'.  For example:
     loglevel= Information|warning|error
Logoutput
Specifies the full pathname of the log file to write to. For example:
     logoutput=c:\logfiles\intel-service-project1.log
Database
Specifies the full path name of the Code Miner database to be loaded. For example:
     database=c:\intel--service\project1.cdb
Multiple 'database' directives are allowed, each specifying a different database.
Allow
Identifies the IP address that is permitted to connect to the service on the Port. For example:
     allow=localhost
     allow=127.0.0.1
     allow=172.160.*      (wildcards are allowed when the 'network'
                                      directive has a value of 'network' or 'public',
                                      but not 'local')
Network
Allows service connections to be restricted.
  • local - the service can’t be heard on any connection other than localhost
  • network - when used with wildcard 'allow' directives, it allows clients on an allowed IP address wild card to connect
pubic - allows any connection
Show When 'true', the Console window for the service will be shown; the default is 'false'.
Port The Port on which the service will be heard
Please contact us or write an email to This email address is being protected from spambots. You nedd JavaScript enabled to view it. or call us @+91 8248004261 to have a live demo about the new EA 16 features and capabilities.
Click here to see a sneak peak of how Code Analyzer in EA16 works.
