Displaying items by tag: C#
Saturday, 15 April 2017 20:35
Use C#, Java, for your VB Scripting
 Use C#, Java from your EA Context Menu:
This works for all EA Versions, even without Administration rights to install an Add-In or so.
EA Version 13 supports an IDE to develope in C# and Java with full EA API support and debugging. They name it Hybrid Scripting. You may use the EA 13 Hybrid Script environment or other IDEs. Going the first steps is easier with EA 13.
This article shows you with a little example how to use C# for your Scripting. After you have understood C#, it should be easy to use Java in a similar way. The main idea is to use a small wrapper you call within your VB Script. Of course, after you have understood it's also easy to write this little wrapper for JavaScipt/JScript.
SPARX delivers two DLLs to use the EA API efficiently. With these DLLs, you can use the EA Hybrid development environment as well as any other IDE you like most. In other words: You can use the power of state of the art languages to perform your scripting. Integrating Scripting in EA is as easy as you know it from the well-known Scripting Languages VB Script, JavaScript, JScript. This without installing anything or needing Admin rights.
Just insert the line:
  • 'RunCommand("myLogic.exe, "", " ")'
in your VB Script and you are done with VBScript to call your C#. Java would be similar.
Let's make a quick example with EA Version 13 and C#:
Make an EA C# ConsoleApplication
  • Create a new EA Project
  • Create a Package ('Select and Apply Model Pattern')
    • C#, RepositoryInterface 4.0
    • c:\temp\hybrid
  • Build the Application
  • Have a look in the generated Application
    • c:\temp\hybrid\RepositoryInterface 4.0\
Import VBScript wrapper to call C#
  • Configure, Transfer, Import Reference Data
  • Make EA Scripting visible
    • Code, Scripting (you may have to refresh Scripts)
  • You see the new VB Scripts inside the ScriptGroup HybridScripting:
    • RunCommand
    • RunCommandTest
Run C# ConsoleApplication.exe
  • Adapt VBScript RunCommandTest
    • Adapt path to 'ConsoleApplication.exe'
  • See
    • Line:28/29 Needed references
    • Line:35      Path to *.exe which executes your logic
    • Line:36      The call of the wrapper, result contains the StandardOutput of the Script
  • Run VBScript RunCommandTest
    • Right Click on RunCommandTest
    • Run Script
How do you use it
There are two approaches: Generates you VB Script by inserting the the wrapper Call in the EA templates at the appropriate location. The other way is to remove the template and just call the wrapper like
'result = RunCommand("myLogic.exe, "", " ")'
instead of the using the template scuffold.
Under the hood
EA delivers the two dlls:
  • Interop.EA.dll
  • SparxSystems.Repository.dll
They expect the Process ID, first parameter, to know which EA Instance the *.exe wants to use. So, RunCommands makes:
  • Estiminate the own Process ID
  • Call 'RunCommand...'
  • Reads the Standard output from your *.exe
  • Returns to Standard output to the caller
Inside the *.exe you have full access to the EA API.
JavaScript, JScript, Java?
With this example it's easy to migrate 'RunCommand' to JavaScript or JScript. Remember, you can use every Language supported by EA and every IDE you like most.
References
As part of an EA add'in implementation, I had to import all Enterprise Architect table and column names in enumeration classes.
Having access to a database that stores a Sparx Systems Enterprise Architect project (e.g. MySQL, SQL Server, or even an EAP file via ODBC), there was a number of ways to populate enumeration classes with literal values using a small application in C# or another programming language. As Enterprise Architect 12 includes the Database Builder, an integrated tool to work on DB schemas, I took the opportunity to use it. Compared with the result of a C# application, this feature would let me capture the enumeration classes in my EA modelling project in addition to generating C# enumeration classes in my add'in solution.
This article only covers a small portion of Sparx EA Database Builder features: it illustrates how I managed to import Enterprise Architect table names as literal values in the EADBTableType enumeration class, and their column names as literal values in separate enumeration classes e.g. t_diagramColumnType, t_objectColumnType...
Import all tables in Enterprise Architect
- Open the menu Tools > Database Builder
- Right click and select New Data Model:
- Select the DBMS used, e.g. MySQL and confirm Ok
- Right click on MySQL > Load
- Right click on Connections > Add new DB connection
- Open the new DB connection and select ODBC based datatype
- Select an existing ODBC DSN (or create one) to the DB that stores the Enterprise Architect project where the schema needs to be imported
- Right click on MySQL > Import DB Schema from ODBC
- Click on Import and select all tables:
- All tables, columns, primary keys, foreign keys, indexes, etc. have been imported.
- Go back to the Database builder and open the Tables tabs: all tables are displayed. Selecting one of the tables provides access to all columns' details.
Generate the enumeration classes
The Database Builder let me achieved what I needed. Having all tables and columns stored in a single package, I wrote a simple script to perform the following:
- create an enumeration class named EADBTableType
- for each table:
    - create a literal value with the table name in EADBTableType e.g. t_object
    - create an enumeration class named after the table based on the following format: <table name>ColumnType e.g. t_attributeColumnType
    - for each column in the table:
       - create a literal value with the column name in the current table's enumeration class (e.g. Classifier in t_attributeColumnType)
Having executed this script, the following enumeration classes have been generated:
Transform enumeration classes to dotNet C# classes
The MDA model transformation can be used to generate C# enumeration classes for the above enums:
- Right click on the package that contains all enums > Advanced > Transform Package
- Select C# as the target, select the package, and click on Do Transform
- Having all C# enumeration classes created, and making sure the namespace is correct (e.g. create packages myaddin.common.enums), the code can be generated: right click on package > Code Engineering > Generate Source Code.
- The generated code can be used in Visual Studio IDE:
