Displaying items by tag: product line engineering
Photo by Mr Cup / Fabien Barral on Unsplash unsplash-logoMr Cup / Fabien Barral
Have you ever wanted to generate code from your Enterprise Architect UML or SysML models? Have you tried to customize Enterprise Architect’s code template framework? Do not give up the dream of project-specific code generators and read how easily they can be implemented.
The Need for a Code Generator
A good software or system architecture is on a higher abstraction level compared to the implementation. It should be a consistent model that documents decisions and neglects unnecessary, often technical, details. Consider, for instance, the class diagram in Figure 1. It shows a domain model that defines the data structure needed for a shop to allow customers to order articles. The properties of each class are modeled in detail, but other unnecessary aspects like operations to access properties are left out.
Example UML model
Figure 1: Example UML model
If the software architecture/design is made upfront before starting with the implementation, a lot of cumbersome and error-prone work can be avoided by code generation. Commercial out-of-the-box code generators often do not change the degree of abstraction. That’s why they often do not match the needs of the project.
The code template framework of Enterprise Architect can be tailored according to the project-specific needs. But this requires some initial training. And often the expected outcome is hard to achieve as described in Eclipse-based Code Generation for Enterprise Architect Models.
A Simple Project-specific Code Generator
I prefer a general-purpose programming language such as Java or Xtend to implement code generators. In particular Xtend is well suited to implement templates because of its template expressions. They allow one to embed executable code inside the text to be generated. It feels like programming PHP, JSP, or JSX. The code in Listing 1 shows a code generation template written in Xtend. It generates Java classes for the classes declared in the class diagram of Figure 1.
package com.yakindu.ea.examples.orderingsoftware.template
import com.yakindu.bridges.ea.examples.runtime.codegen.EACodegen
import org.eclipse.uml2.uml.Class
import org.eclipse.uml2.uml.NamedElement
class ClassTemplate {
   @EACodegen("Java")
   def String generate(Class element) '''
      package «element.package.javaQualifiedName»;
      «val superType = element.generals.findFirst[true]?.name»
      «val extends = '''«IF !superType.isNullOrEmpty» extends «superType»«ENDIF»'''»
      public«IF element.isAbstract» abstract«ENDIF» class «element.name»«extends» {
         «FOR attribute : element.ownedAttributes SEPARATOR System.lineSeparator»
            «val type = attribute.type?.javaQualifiedName»
            «IF 1 != attribute.upper»
               «val defaultValue = '''new java.util.LinkedList<«type»>()'''»
               private final java.util.List<«type»> «attribute.name» = «defaultValue»;
            «ELSE»
               private «type» «attribute.name»;
            «ENDIF»
         «ENDFOR»
               public List<«type»> get«attribute.name.toFirstUpper»() {
                  return «attribute.name»;
            «ELSE»
               public «type» get«attribute.name.toFirstUpper»() {
            «ENDIF»
            «IF 1 == attribute.upper»
               «val params = '''«type» «attribute.name»'''»
               public void set«attribute.name.toFirstUpper»(«params») {
                  this.«attribute.name» = «attribute.name»;
            «ENDIF»
         «ENDFOR»
   protected def String getJavaQualifiedName(NamedElement element) {
      element.qualifiedName.replace("::", ".")
Listing 1: Example code generation template written in Xtend
The generated Java code shown in Listings 2, 3 and 4 does not look like handwritten, because qualified names are used instead of imports. This will be improved later in Figure 4 by methods collectImports and printImports.
package com.example.orderingsoftware;
public abstract class AbstractIDObject {
   private java.util.UUID id;
   public java.util.UUID getId() {
      return id;
   public void setId(java.util.UUID id) {
      this.id = id;
Listing 2: Java code of class AbstractIDObject generated by the code generation template in Listing 1
public class OrderItem extends AbstractIDObject {
   private java.math.BigInteger amount;
   private com.example.orderingsoftware.Article article;
   public java.math.BigInteger getAmount() {
      return amount;
   public void setAmount(java.math.BigInteger amount) {
      this.amount = amount;
   public com.example.orderingsoftware.Article getArticle() {
      return article;
   public void setArticle(com.example.orderingsoftware.Article article) {
      this.article = article;
Listing 3: Java code of class OrderItem generated by the code generation template in Listing 1
public class Order extends AbstractIDObject {
   private java.util.Date date;
   private com.example.orderingsoftware.Customer customer;
   private final java.util.List<OrderItem> items = new java.util.LinkedList<OrderItem>();
   public java.util.Date getDate() {
      return date;
   public void setDate(java.util.Date date) {
      this.date = date;
   public com.example.orderingsoftware.Customer getCustomer() {
      return customer;
   public void setCustomer(com.example.orderingsoftware.Customer customer) {
      this.customer = customer;
   public java.util.List<com.example.orderingsoftware.OrderItem> getItems() {
      return items;
Listing 4: Java code of class Order generated by the code generation template in Listing 1
If you look carefully at the template in Listing 1, you will realize that it does not know anything about Enterprise Architect. Instead, it handles instances of the UML metamodel which is available in Eclipse thanks to the Eclipse UML 2 project. The missing connection between Enterprise Architect and UML is the YAKINDU EA-Bridge. It is an API that offers UML-compliant read and write access to Enterprise Architect UML and SysML models. The database behind an Enterprise Architect project is automatically transformed into instances of the UML metamodel. This has three major advantages for you as a developer:
  • Your code is compatible with other tools that are based on the UML 2 project such as Papyrus.
  • Highly performant read and write access to Enterprise Architect models without the need to reverse engineer the database schema of Enterprise Architect.
  • You do not have to learn anything about the API of the YAKINDU EA-Bridge. It is completely hidden for you as a developer, because the YAKINDU EA-Bridge integrates itself into the ecosystem of the Eclipse Modeling Framework (EMF).
The YAKINDU EA-Bridge comes with an optional Eclipse IDE integration which allows one to implement project-specific code generators. Those code generators are often prototypically developed and are executed only within a certain context. Thus, it is crucial that the development effort is less compared to  manual coding. To implement a project-specific code generator, all you have to do is to place the EAP file in an Eclipse project and to annotate methods in the code generation template with @EACodegen. Annotated methods should accept the UML element for which code should be generated as the only parameter and return the generated text. If your Enterprise Architect model is hosted by a remote database such as Microsoft SQL Server, you can use a shortcut file instead of an EAP file.
When the project is built, e.g. automatically or manually via the main menu item ‘Project, Clean…‘, the template is launched for all UML classes declared in all EAP files. Of course, only EAP files stored in the template’s project are considered. The generated code is saved in a file specified by the qualified name of the class. The file extension is specified by the argument of the @EACodegen annotation. The structure of the Eclipse project can be seen in Figure 2.
Example project structure in Eclipse
Figure 2: Example project structure in Eclipse
Please observe that the YAKINDU EA-Bridge is an API. It allows you to process the Enterprise Architect model in any way. Indeed, the original use case were comprehensive code generators such as an Autosar RTE generator based on UML architectures.
Generating More than one Artefact per Model Element
Let’s make the example more exciting by implementing a product line with two different persistence approaches: One that uses JPA to store data in a relational database and one that uses HBase as a big data store.
I suggest implementing a persistence manager which can be used to load and save instances. Only the product based on JPA should allow one to start and complete transactions. Furthermore, I would like to place JPA specific annotations in the Java classes. Figure 3 shows the methods offered by the persistence manager.
Outline of class PersistenceManager handling the the domain classes in Figure 1
Figure 3: Outline of class PersistenceManager handling the the domain classes in Figure 1
The consequence is now, that the implementation of all six classes is slightly different in both products. The Java code in Listings 5, 6, 7 and 8 shows an excerpt of the code to be implemented.
public class Article extends AbstractIDObject {
   private String name;
   public String getName() {
      return name;
   public void setName(String name) {
      this.name = name;
Listing 5: Java code of class Article with HBase as persistence approach
import javax.persistence.Entity;
import javax.persistence.Table;
@Entity
@Table(name = "ArticleTable")
      return name;
      this.name = name;
Listing 6: Java code of class Article with JPA as persistence approach
public class PersistenceManager implements AutoCloseable {
   private final Table articleTable;
   public static final byte[] MODEL_FAMILY = "Model".getBytes();
   public static final TableName ARTICLE_TABLE_NAME = TableName.valueOf("ArticleTable");
   public Article getArticle(UUID id) {
      try {
         if (id != null) {
            Get get = new Get(id.toString().getBytes());
            if (articleTable.exists(get)) {
               Result r = articleTable.get(get);
               Article result = new Article();
               result.setId(id);
               result.setName(Bytes.toString(r.getValue(MODEL_FAMILY, ARTICLE_NAME_QUALIFIER)));
               return result;
         return null;
      } catch (Exception e) {
         throw new RuntimeException(e.getMessage(), e);
Listing 7: Excerpt of the Java code of class PersistenceManager with HBase as persistence approach
   private EntityManager entityManager;
      if (id != null) {
         return entityManager.find(Article.class, id);
      } else {
         return null;
Listing 8: Excerpt of the Java code of class PersistenceManager with JPA as persistence approach
Feasible solutions to realize the product line are:
  • To use inheritance. That would require an interface definition with the public API for each class and to implement it for JPA and for HBase. The consequence would be that the rest of the application must be adjusted to operate only on the interfaces and never on the concrete classes.
  • To copy, paste, and modify the implementation for both products would avoid the need to modify the rest of the application. Maintaining two variants might sound reasonable. But is this still the case with an increasing amount of variants? You should think carefully about the pros and cons of copy and paste.
  • To use a code generator which generates the product specific code. The classes realizing code generation templates could be based on a common implementation and each subclass could adjust the product-specific parts.
I prefer the last solution. The outline in Figure 4 shows the refactored class template of Listing 1. Each introduced method generates a specific member of a Java class. This allows me to override these methods in the product-specific templates. In Listing 9 for instance can be seen, that JPA specific annotations are placed before the class definition.
Outline of the refactored class ClassTemplate
Figure 4: Outline of the refactored class ClassTemplate
class JPAClassTemplate extends ClassTemplate {
   @EACodegenFile
   def IFile path(Class element, IFile ^default) {
      val path = "com/example/orderingsoftware/" + ^default.name
      return getTargetFilePath("jpa", path)
   @EACodegen("java")
   override generate(Class element) {
      return super.generate(element)
   override printClassDeclaration(Class element) '''
         @MappedSuperclass
      «ELSE»
         @Entity
         @Table(name = "«element.name»Table")
      «ENDIF»
      «super.printClassDeclaration(element)»'''
Listing 9: Excerpt of the code generation template for JPA written in Xtend
The method path(Class, IFile) in the template subclasses annotated with @EACodegenFile is used to define the target location at which the generated code should be saved. It has two parameters. The first one is the UML element for which code should be generated. The second is the default location where the generated code should be stored. The return value of the annotated method is the adjusted location at which the generated code should be stored.
The screenshot in Figure 5 shows all templates. The arrows point to the files that are generated by each of them. In addition to the production code, also the test code is generated.
Code generation templates for JPA and HBase and the generated source files
Figure 5: Code generation templates for JPA and HBase and the generated source files
Modern general-purpose programming languages such as Xtend are well suited to implement complex code generators. The input could be a UML model, possibly modeled in Enterprise Architect. The YAKINDU EA-Bridge transforms the relational database behind an Enterprise Architect model on the fly, and completely hidden, into instances of the UML metamodel. There is no need to learn the proprietary code generation language provided by Enterprise Architect or to reverse engineer the database schema of Enterprise Architect.
The Eclipse IDE integration of the YAKINDU EA-Bridge allows one to implement project-specific code generators at low costs in a short time. In this way, you can save a lot of cumbersome, error-prone, and mindless implementation work.
If you want to see and run the full example for yourself, try out the YAKINDU EA-Bridge. The presented example is one of the examples shipped with the YAKINDU EA-Bridge.
BigLever Software™, the leading provider of systems and software product line engineering (PLE) solutions, has announced the release of Gears 7.2, the latest version of the company’s industry-standard PLE Lifecycle Framework. Gears 7.2 delivers the breakthrough multistage configuration capabilities needed for engineering organizations to create, deliver, maintain and evolve their entire “product family tree” based on product line features. This new feature-based product line family management capability is changing the way companies, across a spectrum of industries, evolve and compete with their product lines.
In successful commercial product line organizations, the number and diversity of products delivered can grow to be extremely large, partially due to the efficiencies made available by the latest generation of PLE tools and methods. In market segments ranging from automobiles to industrial systems, it is not unusual for companies to manufacture millions of products every year, in thousands of different “flavors”. This extreme product line diversity creates major challenges for engineers implementing the product line, product marketers defining the space of available products, and customers selecting from the array of available products. To provide order and clarity about their product groupings and offerings within this type of complex product space, companies often organize their products into a product family tree, thereby enabling customers to more easily navigate among the huge number of product offerings.
BigLever’s Gears solution dramatically reduces engineering complexity by enabling companies to establish a feature-based product line factory that uses feature profiles and systems and software assets – from across the engineering lifecycle and the entire product line portfolio – to automatically configure and produce their many product flavors.
Multistage configuration extends this product line factory approach by allowing product line managers and marketers to better comprehend, organize and manage highly complex family trees based on product line features.
"Multistage configuration is especially powerful because it shortens the lead time required to translate new feature concepts and combinations into product implementation," said Dr. Charles Krueger, CEO of BigLever Software. "With Gears 7.2, product marketers can gain a cohesive big picture view into the product family tree, and the subfamlies within their purview, to take strategic advantage of product feature commonalities and diversity within the product space. As a result, businesses can leverage a feature-based product line management approach to efficiently expand and evolve their product line portfolio to meet customer need and market demand."
"Dealing with this kind of complexity is a challenge that hits hard in the systems engineering arena, where the disparate worlds of software and hardware come together," said Tony Baer, Principal Analyst, Ovum. "As ALM (application lifecycle management) and PLM (product lifecycle management) technologies begin to converge, much of the industry’s focus is on integrating the tools, rather than integrating the business across these two critical functions. BigLever’s feature-based product family management approach can play a role in helping engineering and product management establish a common vision for the product line."
About Product Line Engineering
The emergence of PLE as mainstream practice in the systems and software engineering industry is due in large part to the latest generation of pragmatic, full-lifecycle PLE tools and methods. First generation PLE approaches enable the improved reuse of software assets; however, they tend to focus on techniques for enhancing variation management within a single tool, a single asset type, or at an individual stage in the lifecycle. Second generation PLE (2GPLE) is centered on the featured-based product line factory paradigm. With 2GPLE the entire product line portfolio is engineered, managed, delivered and evolved as a single, feature-based, automated production system – as opposed to a multitude of separate products.
BigLever’s Gears PLE Lifecycle Framework is the only PLE solution that allows organizations to create a supply chain of product line assets that self-configure based on features, automatically assemble these self-configuring assets from across the lifecycle, and produce the product line family with the push of a button
About Gears 7.2 and Multistage Configuration
Gears 7.2 supports the engineering, deployment and maintenance of complex product family trees by enabling feature selections and "downselections" (features removed from consideration) to be incrementally staged throughout the nodes in a product family tree. Feature decisions made at any node are inherited by all descendants of that node, thereby defining a product family subtree. For example, an automotive manufacturer might structure their product line portfolio into a family tree with 5 levels:
* Platform: A family of vehicles of similar size and structure that can be manufactured in the same assembly plant. (Examples might include pickup trucks, large sedans, and small coupes.)
* Program: A subfamily of vehicles within a single platform, known by consumers as the “model”.
* Regional program: A subfamily of vehicles within a single program, manufactured for the legislative, geographic, climate, cultural, and marketing characteristics of a particular country.
* Trim level: A subfamily of vehicles within a single regional program, representing different tiers of capabilities, accessories, and associated cost using terms such as base, standard, and luxury.
* Vehicle instance: A subfamily member within a single regional program trim level, as determined by the consumer-selectable options available on a particular trim level.
This patent pending multistage configuration capability has been adopted by the world’s leading automotive manufacturer to streamline and simplify the engineering, delivery and evolution of one of the most complex product lines in the world. In addition to the automotive industry, companies in other sectors are leveraging this approach to deliver complex product families, such as a portfolio of industrial pump systems.
Enterprise Architect / Gears Integration
BigLever provides a bridge integration product for integrating Sparx Systems Enterprise Architect with the company's Gears solution. The Enterprise Architect/Gears Bridge™ allows the Sparx Systems user community to support product line variability by making Enterprise Architect "product line aware". By becoming product line aware, Enterprise Architect connects directly to BigLever's Gears Framework, enabling it to work synchronously with other product line aware tools across the engineering lifecycle.
About BigLever Software
BigLever Software, the leading provider of systems and software product line engineering framework, tools and services, dramatically simplifies the creation, evolution, maintenance and delivery of a product line – a portfolio of similar products or systems with variations in features and functions. BigLever’s patented Gears solution enables organizations to reduce development costs and bring new product line features and products to market faster, enabling businesses to more reliably target and hit strategic market windows. BigLever is based in Austin, Texas. For more information, visit www.biglever.com.
