Displaying items by tag: rtf templates
Bellekens DocGen example
  • Step 1: Create the virtual document with a script
  • Step 2: Generate the document from the virtual document
Document generation is important in most organisations that work with Enterprise Architect. Storing information in the model is good, but most stakeholders still require documents.
Documents are using as a tool for validation, as a work order, or just to give you an overview of a specific set of thing in the model. The main advantages of a document versus a model is that it has a limited scope and a linear order. You can read a document from start to finish, whereas you cannot do that with a model. Documents are, and will always be an important tool in developing applications.
Enterprise Architect comes with a sophisticated document generator that has seen great improvements in the last versions (v10, v11, v12). You also get a standard set of document templates that will quickly generate a document for a part of your model.
The problems arise however the moment you try to do something a bit more sophisticated with the document templates. Get information from different packages, use different templates for the same (set of) elements, etc… You will quickly realize that the approach of having one large template that generates the whole document is not useful for real-world document requirements.
Luckily EA has an alternative to the single template approach: Virtual Documents
Free Download
I’ve put together an example model and an MDG to demonstrate this approach. The MDG contains all scripts, templates and SQL Searches to generate a decent Use Case Document.
Bellekens DocGen MDG and example model
€0.00
 After you open the Hotellio.eap file, right click on the Reservations use case diagram and choose Create Use Case Document
Then select the package to store the virtual document in and fill in the version.
Finally select the «master document» package and press F8 so start the document generation. Make sure to select the correct cover page and style sheet
Generate Document
Virtual Documents
Virtual Documents are used to define the contents of a document as a set of individual sections, each with its own source and template.
Virtual Documents structure
There are two types of elements that are used for virtual documents
  • Master Document
    Represents the document to be printed. You can give it some parameters that can be used in the document itself such as title, Version, Status, etc…
  • Model Document
    Represents a section in your document. The model document gets an RTFTemplate, and you have to define a source for this section. The source tell us which element(s) from the model should be used in this section. There are two ways to define the source. You can either drag one or more packages onto it, or you can fill in the Model Search and Search Term.
Master Documents get stored in the model as stereotyped packages and they contain stereotypes classes to represent the Model Documents
Virtual Document example
In the project browser this looks like thisVirtual Document project browser.
The Master Documents get the stereotype «master document» They contain tagged values to store things like ReportAlias, ReportTitle. Event though you can assign an RTF template to the master document this seems to be pointless since it gets ignored when printing a document.
Model Documents get the stereotype «model document». The links to the packages that serve as the source for a model document are created by dragging the package from the project browser onto the model document. This creates an attribute that maintains the link to the package.
Tagged values are used to indicate the template to use, the model search to use, and the search value to use on that search.
This mechanism of model documents allows you to very precisely control what will be printed in the document.
Templates
RTF templates are stored in the Resources section of your model. In order to see and manage them enable the resources view using View|Resources
template sections
Templates for document that have a package as source can start from the package tag and access all element, diagram etc.. in that package.
If your source is an SQL search that returns elements your template content can be placed in the element section
SQL Search
The SQL search I use to select a single element based on its GUID this following:
1
2
3
4
5
6
7
8
9
select c.ea_guid AS CLASSGUID,c.object_type AS CLASSTYPE,c.name AS Name, c.stereotype AS Stereotype,
package.name AS PackageName ,package_p1.name AS PackageLevel1,package_p2.name AS PackageLevel2,package_p3.name AS PackageLevel3
from ((((t_object c
inner join t_package  package on c.package_id = package.package_id)
left join t_package  package_p1 on package_p1.package_id = package.parent_id)
left join t_package  package_p2 on package_p2.package_id = package_p1.parent_id)
left join t_package  package_p3 on package_p3.package_id = package_p2.parent_id)
where
c.ea_guid like '<Search Term>'
Printing
When you select the Master Document you can open up the document generation dialog by pressing F8
Generate Document
Here you can set the cover page, table of contents, and the style sheet to use.
Side note: Invest in the style sheet. It will save you time and frustration afterwards. It is difficult, and awkward to set styles using the RTF editor, but if you do it once in the stylesheet you don’t have to to it over and over again in each template. Also make sure to create your own “normal” style and call it “my normal” or something like that. Use this instead of the regular “normal”. There seems to be some weird behavior associated by the “normal” style, so I learned it’s best not to use it at all.
Then press generate, and the document generator will create one big document containing
  • The cover page
  • The table of contents page
  • All model documents in the order they appear in the project browser.
If you are not happy with the content of the document, or the order of the model documents then you can change them in EA and re-print the document.
One of the advantages is that the content of the document is stored in EA. So after a revision of the model you can print exactly the same content again and compare it with the previous version.
 Automatically generate virtual documents
Using virtual documents like that is all nice and good, but it still requires quite a lot of work to assemble the virtual document itself. For a somewhat realistic document you easily end up with tens of model documents, all pointing to different element or packages, and different template.
And you have to repeat that process for all the different documents you want to generate.
Doing the same thing over and over again is exactly what computers are build for. Instead of having to assemble the virtual document manually we will write a little script to do it for us.
The first thing well need to do is to make the Master Document package. This VBScript function does that for us.
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
function addMasterDocument(packageGUID, documentName,documentVersion,documentAlias)
    dim ownerPackage as EA.Package
    set ownerPackage = Repository.GetPackageByGuid(packageGUID)
    dim masterDocumentPackage as EA.Package
    set masterDocumentPackage = ownerPackage.Packages.AddNew(documentName, "package")
    masterDocumentPackage.Update
    masterDocumentPackage.Element.Stereotype = "master document"
    masterDocumentPackage.Alias = documentAlias
    masterDocumentPackage.Version = documentVersion
    'link to the master template
    dim templateTag as EA.TaggedValue
    for each templateTag in masterDocumentPackage.Element.TaggedValues
        if templateTag.Name = "RTFTemplate" then
            templateTag.Value = "(model document: master template)"
            templateTag.Notes = "Default: (model document: master template)"
            templateTag.Update
            exit for
        end if
    next
    'return
    set addMasterDocument= masterDocumentPackage
end function
Then we need to make the Model Documents.To make one with a Package as source we use this function
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
function addModelDocumentForPackage(masterDocument,package,name, treepos, template)
    dim modelDocElement as EA.Element
    set modelDocElement = masterDocument.Elements.AddNew(name, "Class")
    'set the position
    modelDocElement.TreePos = treepos
    modelDocElement.StereotypeEx = "model document"
    modelDocElement.Update
    'add tagged values
    for each templateTag in modelDocElement.TaggedValues
            templateTag.Value = template
            templateTag.Notes = "Default: Model Report"
            templateTag.Update
            exit for
        end if
    next
    'add attribute
    dim attribute as EA.Attribute
    set attribute = modelDocElement.Attributes.AddNew(package.Name, "Package")
    attribute.ClassifierID = package.Element.ElementID
    attribute.Update
end function
To make one with an SQL Search as source we use this function
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
function addModelDocumentWithSearch(masterDocument, template,elementName, elementGUID, treepos, searchName)
    dim modelDocElement as EA.Element;
    set modelDocElement = masterDocument.Elements.AddNew(elementName, "Class")
    'set the position
    if len(elementGUID) > 0 then
                templateTag.Update
            elseif templateTag.Name = "SearchName" then
                templateTag.Value = searchName
                templateTag.Update
            elseif templateTag.Name = "SearchValue" then
                templateTag.Value = elementGUID
                templateTag.Update
            end if
        next
    else
        'add tagged values
                templateTag.Update
                exit for
            end if
        next
        'no GUID provided. Set masterdocument package ID as dummy attribute to make the template work
        set attribute = modelDocElement.Attributes.AddNew(masterDocument.Name, "Package")
        attribute.ClassifierID = masterDocument.Element.ElementID
        attribute.Update
    end if
end function
The the last script we is one to actually use these functions in order to create the virtual document. In the example provided I’ve split the script in two parts. One part that remains in the library, and one script that is put in the Diagram Group so we can call it from a diagram directly.
The script in the Diagram Group takes care of getting the user input
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
option explicit
!INC Bellekens DocGen.UseCaseDocument
' Script Name: Create Use Case Document
' Author: Geert Bellekens
' Purpose: Create the virtual document for a Use Case Document based on the open diagram
'           Copy this script in a Diagram Group to call it from the diagram directly.
' Date: 11/11/2015
sub OnDiagramScript()
    dim documentsPackage as EA.Package
    'select the package to generate the virtual document in
    Msgbox "Please select the package to generate the virtual document in",vbOKOnly+vbQuestion,"Document Package"
    set documentsPackage = selectPackage()
    if not documentsPackage is nothing then
        ' Get a reference to the current diagram
        dim currentDiagram as EA.Diagram
        set currentDiagram = Repository.GetCurrentDiagram()
        if not currentDiagram is nothing then
            createUseCaseDocument currentDiagram, documentsPackage.PackageGUID
            Msgbox "Select the Master Document and press F8 to generate document",vbOKOnly+vbInformation,"Finished!"
        else
            Session.Prompt "This script requires a diagram to be visible", promptOK
        end if
    end if
end sub
OnDiagramScript
The script in the library will use the functions mentioned above to start building the virtual document
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
!INC Local Scripts.EAConstants-VBScript
!INC Bellekens DocGen.DocGenHelpers
!INC Bellekens DocGen.Util
' Script Name: UseCaseDocuemnt
' Purpose: Create the virtual document for a Use Case Document based on the given diagram
' Date: 11/11/2015
dim useCaseDocumentsPackageGUID
function createUseCaseDocument( diagram, documentsPackageGUID)
    useCaseDocumentsPackageGUID = documentsPackageGUID
    'first create a master document
    dim masterDocument as EA.Package
    set masterDocument = makeUseCaseMasterDocument(diagram)
    if not masterDocument is nothing then
        dim i
        i = 0
        'use case diagram part 1
        addModelDocumentForDiagram masterDocument,diagram, i, "UCD_Use Case Diagram"
        i = i + 1
        'add Actors
        dim diagramPackage as EA.Package
        set diagramPackage = Repository.GetPackageByID(diagram.PackageID)
        addModelDocumentForPackage masterDocument, diagramPackage, diagram.Name & " Actors", i, "UCD_Actors"
        i = i + 1
        ' We only want to report the use cases that are shown within the scope boundary on this diagram
        'get the boundary diagram object in the diagram
        dim boundaries
        set boundaries = getDiagramObjects(diagram,"Boundary")
        Session.Output boundaries.Count
        'get the use cases
        dim usecases
        if boundaries.Count > 0 then
            set usecases = getElementsFromDiagramInBoundary(diagram, "UseCase",boundaries(0))
            Session.Output "boundary found"
        else
            set usecases = getElementsFromDiagram(diagram, "UseCase")
        end if
        'sort use cases alphabetically
        set usecases = sortElementsByName(usecases)
        'add the use cases
        i = addUseCases(masterDocument, usecases, i)
        Repository.RefreshModelView(masterDocument.PackageID)
        'select the created master document in the project browser
        Repository.ShowInProjectView(masterDocument)
    end if
end function
function makeUseCaseMasterDocument(currentDiagram)
    'we should ask the user for a version
    dim documentTitle
    dim documentVersion
    dim documentName
    dim diagramName
    set makeUseCaseMasterDocument = nothing
    diagramName = currentDiagram.Name
    'to make sure document version is filled in
    documentVersion = ""
    documentVersion = InputBox("Please enter the version of this document", "Document version", "x.y.z" )
    if documentVersion <> "" then
        'OK, we have a version, continue
        documentName = "UCD - " & diagramName & " v. " & documentVersion
        set masterDocument = addMasterDocumentWithDetails(useCaseDocumentsPackageGUID, documentName,documentVersion,diagramName)
        set makeUseCaseMasterDocument = masterDocument
    end if
end function
'add the use cases to the document
function addUseCases(masterDocument, usecases, i)
    dim usecase as EA.Element
    for each usecase in usecases
        'use case part 1
        addModelDocument masterDocument, "UCD_Use Case details part1", "UC " & usecase.Name & " Part 1", usecase.ElementGUID, i
        i = i + 1
        'get the nested scenario diagram
        dim activity as EA.Element
        set activity = getActivityForUsecase(usecase)
        'add scenario diagram
        if not activity is nothing then
        addModelDocument masterDocument, "UCD_Use Case Scenarios Diagram", "UC " & usecase.Name & " Scenarios diagram", activity.ElementGUID, i
            i = i + 1
        end if
        'use case part 2
        addModelDocument masterDocument, "UCD_Use Case details part2","UC " &  usecase.Name & " Part 2", usecase.ElementGUID, i
        i = i + 1
    next
    'return the new i
    addUseCases = i
end function
function getActivityForUsecase(usecase)
    set getActivityForUsecase = getNestedDiagramOnwerForElement(usecase, "Activity")
end function
function getInteractionForUseCase(usecase)
    set getInteractionForUseCase = getNestedDiagramOnwerForElement(usecase, "Interaction")
end function
function getNestedDiagramOnwerForElement(element, elementType)
    dim diagramOnwer as EA.Element
    set diagramOnwer = nothing
    dim nestedElement as EA.Element
    for each nestedElement in element.Elements
        if nestedElement.Type = elementType and nestedElement.Diagrams.Count > 0 then
            set diagramOnwer = nestedElement
            exit for
        end if
    next
    set getNestedDiagramOnwerForElement = diagramOnwer
end function
'sort the elements in the given ArrayList of EA.Elements by their name
function sortElementsByName (elements)
    dim i
    dim goAgain
    goAgain = false
    dim thisElement as EA.Element
    dim nextElement as EA.Element
    for i = 0 to elements.Count -2 step 1
        set thisElement = elements(i)
        set nextElement = elements(i +1)
        if  elementIsAfter(thisElement, nextElement) then
            elements.RemoveAt(i +1)
            elements.Insert i, nextElement
            goAgain = true
        end if
    next
    'if we had to swap an element then we go over the list again
    if goAgain then
        set elements = sortElementsByName (elements)
    end if
    'return the sorted list
    set sortElementsByName = elements
end function
'check if the name of the next element is bigger then the name of the first element
function elementIsAfter (thisElement, nextElement)
    dim compareResult
    compareResult = StrComp(thisElement.Name, nextElement.Name,1)
    if compareResult > 0 then
        elementIsAfter = True
    else
        elementIsAfter = False
    end if
end function
This article was originally published on bellekens.com
Monday, 10 March 2014 11:59
eaDocX v3.4 beta available
Additional document creation options from your Enterprise Architect model are now available with the release of the eaDocX v3.4 beta.
 This latest eaDocX release allows you to:
- construct documents and document sections based on your model views
- use instance classifiers just like any other relationship to provide new document structures
- work with EA scripts to deliver even more tailored document formatting options
- plus other customer requested enhancements
eaDocX v3.4 is compatible with EA v11.
Read more and download a free trial at www.eadocx.com
Tuesday, 16 April 2013 12:25
EA Document creation just got even better
We're pleased to announce the release of eaDocX v3.3, making it even easier to integrate your EA analyses directly into Word and Excel with no need for scripting.
New features include:
- Support for Word and Excel 2013
- Model Expert: a graphical tool to help you understand the structure of your EA model
- Even better Quick documents to create a Word document of any package in your model in just 2 clicks
- Phone home - to keep you up to date with latest releases
- More configurable options for your documents
- Define your own Word Table styles
- and a whole load of other customer requests
For more information and a free 30 day trial visit www.eadocx.com
An important part of implementing Enterprise Architect, as an effective tool for agile analysis and design, is automating generation of project documentation. You need to be able to produce complex and stylised output and this has been a challenge for many. The first of a number of white papers, based on our Master Class training program, this paper looks at how to achieve complete project documents from within your Enterprise Architect models.
Having now implemented EA as the tool for analysis and design, for over 11 organisations, I have found that a critical part of its adoption is the transition from using word to create the project document deliverables - to generating them directly from EA in the form of reports.
In the course of getting there I had to address a number of challenges and the transition was not plain sailing by any means. The good news is if you are aware of the challenges and are willing to put in the effort you can produce high quality documents directly from your project models.
This whitepaper looks at these challenges and how they were overcome using approaches that have worked in large and small organisations enabling them to use EA as the core tool for the production of the various documents that are required during the product development lifecycle.
