Displaying items by tag: sparx ea 16
Custom Documentation
  • Sparx Systems Enterprise Architect has a powerful feature to generate a quick report through the ‘Custom Document’ feature.
  • Beneficial among businesses and firms not only because of the ease of generating reports but also because they are usually quite accurate and uniform.
  • Helps the business to stay competitive by making the right data available to the right people at the right time.
What’s new in Custom Documentation in Sparx Enterprise Architect 16?
  • New custom document templates and sample document contents are available through Model Wizard and can be accessed from Document Publishing perspective.
  • This new documents templates allow you to produce high level design, functional and business requirement document.
  • Creating a Custom Document is fairly simple, and you can generate a document with a few clicks by simply dragging and dropping a model content from the Project Browser.
  • It Dynamically updates the entire document or a particular section, ensuring that it reflects the latest changes in the Model. So that, you can save time and avoid regenerating a document then copy-paste the changes in the existing word documents.
  • Warnings are now displayed when data is lost when updating a dynamic part.
  • Ad hoc reporting features allow users to customize to insert their own words, images, logo and other contents to their own requirements.
  • Improved content list, which now includes the element and template for each dynamic part.
  • During document generation, a progress indicator will bring better feedback.
  • Numerous improvements and usability improvements have been made.
Custom Template Figure 1: Custom Templates
Please contact us or write an email to mailto:This email address is being protected from spambots. You need JavaScript enabled to view it. or call us @ +91 8248004261 to have a live demo about the new EA 16 features and capabilities.
Click here to see a sneak peak of how Auto Refresh in EA16 works.
  • User Security in Enterprise Architect is a method of restricting the use of data update functions across the model via access rights for each function, as well as safeguarding individual parts and diagrams from modification using user locks.
  • The primary goal is to avoid unintended data alterations and to prohibit access to sensitive information.
What’s new in Sparx Enterprise Architect 16
  • Sparx Enterprise Architect 16 enhances the model governance by making it much more secure to safeguard your model/project.
  • From Release 16.0 onwards, in the Corporate, Unified, and Ultimate Editions, if security is enabled, access restrictions can be applied to specific users and groups, to prevent certain actions.
  • Prevents data loss in the model/project at the user level on top of the model security authorization and also prevents the unwanted destruction of model data.
  • User limitations prevent a user from completing certain tasks, independent of their other user and group security rights.
  • Restrictions can be applied for deleting packages, diagrams, elements, connectors, attributes, and operations.
  • They may also be used to limit XMI Import, restore from a Baseline, and remove a Baseline. Basically, anything that could result in 'data loss'.
  • These restrictions are aimed at preventing the inadvertent deletion of model content.
User restrictions in Sparx EA 16
        Figure 1 User restrictions in Sparx EA 16
Restrictions
Restriction Prevents the user from
Delete Package Deleting Packages.
Delete Diagram Deleting diagrams.
Delete Element Deleting elements.
Delete Attribute Deleting attributes from elements, or columns from data tables.
Delete Operation Deleting operations from elements, or constraints from data tables.
Delete Connector Deleting connectors.
Import XMI Importing XML Package files (but does not prevent version control imports).
Restore from Baseline 'Restoring' a Package from a previously-saved Baseline.
Delete Baseline Deleting saved Package Baselines.
Please contact us or write an email to This email address is being protected from spambots. You need JavaScript enabled to view it. or call us @ +91 8248004261 to have a live demo of the new EA 16 features and capabilities.
Click here to see a sneak peak of how Enhanced User Security in EA16 works.
