Displaying items by tag: tool selection
Tuesday, 02 April 2019 04:51
Show the Enterprise Architect Toolbox
The Toolbox is an often-essential part of the Enterprise Architect interface. There are several ways to bring up the Toolbox in Enterprise Architect. This tutorial will cover all 4 of them.
1. Via the Ribbon
 ribbontoolbox
Ribbon > Design > Diagram > Toolbox.
2. Using Shortcut Keys
Pressing Alt+5 displays the Diagram Toolbox.
3. Pressing the Space Bar
Brings up the Diagram Toolbox in-place via a context sensitive menu.
 spacebartoolbox
4. Switching between Docked Dialogues
If you like to dock the Toolbox and Project Explorer together in the same spot, the guillemets arrow can allow you to swap back and forth between the two.
 guillemets
P.S. A quick note about Perspectives...
Perspectives in Enterprise Architect are used to tailor toolsets for domain-specific modeling scenarios. So essentially, you can apply a Perspective to display functions/tools appropriate to the task you're performing and hide all the rest.
Sometimes people can't find the tool they're looking for because they have a perspective set and aren't aware. If you ever find yourself in this position, check the perspectives display down the bottom right of the program.
perspectivesnote
Then either select the new relevant perspectives required or set the perspective back to default by Perspective > Activate All.
perspectives
Happy Modeling!
In the last year I have done a number of projects for a Dutch government agency as a data architect. This organisation has an architecture team with four members. There is a problem in producing architecture documents like Project Start Architectures, it takes too much time and the result has limited value for the projects.  This is mainly caused by the lack of overview on the baseline and the target architecture. There is no overview of the business processes, the application and the infrastructure.
For every project, an architect has to do a lot of research on the baseline architecture first, sometimes this activity takes weeks to get a architecture view that is input for working on the target architecture. Another problem is that every architect has his own tools and techniques for the architecture notations and documents. Although there is an architecture document template, there are large differences in the quality and presentation of these documents. However due to the differences in tools and techniques, every architect starts from scratch for every project.
To tackle these problems the team decided to synchronize their activities, techniques, notation and tools. Therefore the following questions where formulated:
·         Which notation is best to support our architecture documents and diagrams?
·         Based on the selected notation, which tool can help us to make our documents more efficiently?
·         What do we have to change in our team to encourage reuse of existing documents and diagrams?
Below I will describe how we looked for answers to these questions and what lessons we have learned.
ArchiMate
In the Netherlands, there are a lot of architecture methods available like Togaf, Zachman, Dragon1, Demo, DyA and ArchiMate.  Each method has its own characteristics. However which are important for our own organisation. The architecture team did an interactive workshop to formulate the following requirements for the architecture methodology:
·         It must be an open standard and is used in other government agencies for exchanging models.
·         Applicable for all aspects of an enterprise architecture, from business to infrastructure and data architecture.
·         It must be easy to use and easy to read for non IT professionals.
In this interactive workshop a number of extra requirements where formulated and most important we defined a multiplier define the importance for each requirement. The requirements were mapped on a number of architecture methodologies and ArchiMate was the methodology with the highest score.
ArchiMate is an open standard with a powerful notation for all the aspects of enterprise architecture. Since ArchiMate 2.0 there are even extensions for motivation like principles, requirements and stakeholders and project management for plateaus, gaps and work packages. In the figure below you see a sample ArchiMate 2.0 diagram.
Figure 1 Sample ArchiMate notation
After this methodology selection the next step was to evaluate it in a number of projects. For ArchiMate there are Visio Stencils and a number of open source tools. Every architect used the notation for a period of time and during this period we organized a number of sessions to discuss the results. We also organized an interactive session with our non IT stakeholders to evaluate the selected methodology.
In these evaluations we discovered that the ArchiMate notation is valuable for describing the architecture in our organisation. For the notation instruction material was made with example diagrams and describing when to use what ArchiMate viewpoints. However the notation is too rich for most of the situations. So the following categories were introduced:
·         Primary diagrams, should be present in every architecture document
·         Secondary diagrams, only available in complex documents for extra description
During the evaluations it became clear that the Visio stencils and open source tooling had insufficient functionality for the next phase, the implementation of the methodology.
Using Enterprise Architect
Like we did with the notation we formulated a number of requirements including a multiplier for each architect and compared a number of tools with each other. This was done with a simple spreadsheet. In the figure below a part of the spreadsheet
Figure 2: Requirement-Tool matrix
Based on the results of this matrix Enterprise Architect had the best score and we introduced the product. This introduction was done in a number of planned steps. There was a risk that the organisation returned to old habits of working in an unstructured way and introducing a architecture methodology combined with tooling has to be embedded in all the activities of the architects.
In the following sessions I will describe a number of important aspects for introducing Enterprise Architect with ArchiMate.
Repository setup
Already in an early phase of the tool introduction we discovered that the repository content can become messy when you do not think about structuring the elements. Although there is a good project browser search function structuring the project so you can browse for elements is a good aid for the users of the system.
The repository is divided in three sections:
·         Projects,  actual project documents in various stages of completion
·         Reference architecture, elements and diagrams from previous projects that are generic and probably reusable in future projects. This section is subcategorized in a structured manner comparable with the ArchiMate layers and columns
·         Archive, diagrams and elements from projects that are probably not reusable.
Figure 3: Repository setup
Document generation
Introducing an architecture methodology in combination with tooling asks a lot of effort from the involved professionals. It was therefore important to seek for a solution to reduce the production time of the architecture documents, this was the reason why we started this project in the first place.
Already in an early phase of the project document generation was investigated as part of the overall solution. Document generation proved to be a great help to achieve this goal. The standard document templates were changed to our own corporate layout and the layout of the elements was changed for a better readability. The repository setup was changed so it was possible to change ordering and exclude packages from the document generation.
Sharepoint Wiki
In the organisation Microsoft SharePoint is the application for team- and project collaboration. The architecture team used this already and has made a lot of information available in a SharePoint wiki. First approach was to transfer this information to Enterprise Architect. However making links to files and Wiki content from the Enterprise Architect packages and elements turned out to be a good solution. With the links from the screens and the generated documentation to the wiki content people can easily get access to background information.
Custodian
In the repository setup a distinct difference is made to project data and generic data of the reference architecture. Especially this reference architecture is an important aspect of introducing standardization and reusability. Therefore the reference architecture needs special governance. The team decided to introduce a custiodian role. This custodian is responsible for the reference architecture package in the repository. To keep this reference architecture up to date the custodian has the following activities:
·         Give information and instructions to team members about the setup of the reference architecture and how to use the elements and diagrams.
·         Give feedback on diagrams and notation made by team members in project documentation.
·         Select generic diagrams and elements from project documentation for transfer to the reference architecture.
This custodian role turned out to be a very good decision to help introduce the ArchiMate notation, the new methodology and the usage of the tooling in a right manner.
Lessons Learned
In one year the organisation introduced a new architecture methodology, notation and tooling. Furthermore the production of architecture documents changed dramatically. Some aspects were successful, while others werenot. The most important lessons we learned are
·         Team involvement,  this is most important to make this a success. Every team member must see the advantages of the new methodology. Furthermore, everybody must be an ambassador and therefore should have sufficient influence on the final product.
·         Notation governance, especially in projects under time pressure, it is so tempting to make an simple diagram in Visio or PowerPoint for a few team members. The role of the custodian is in this important to keep everybody involved!
·         Communicate! A new architecture methodology, notation and tooling has a great impact, not only for the team members but for every stakeholder in the organisation. Take care of informing everybody about results, products and other notifications. We made a number of posters of architecture diagrams for important projects and that helped a lot (see figure 4)
·         ArchiMate 1 and 2, there are two versions of ArchiMate in notation and in Enterprise Architect. At first we decided that we used these notation together. This turned out to be a wrong decision. Not only was it confusing, the tooling has strange behaviour when using the versions simultaneous.
Figure 4 Project Poster
The introduction of ArchiMate in combination with tooling was not always easy. There are a lot of options and it was difficult to make the right choice, especially for the methodology. Introducing a new working proceedure was not simple for evberybody. The custodian role helped a lot here. Enterprise Architect in combination with ArchiMate 2.0 turned out to be a good choice. The tooling is easy to use, has sufficient search capabilities, can be adapted easily for document generation and connection with existing applications like SharePoint.
Published in Case Studies
