Displaying items by tag: windows phone wireframing
sparx enterprise architect 12.1 beta
Sparx Systems released mid September the first beta of Enterprise Architect version 12.1. Full details on this version are available here.
Enterprise Architect User Guide has been redesigned to access the help content from a web browser. By default, the EA user guide is opened on Sparx Systems web site in order to access an up to date help content.
For those who use Enterprise Architect offline, an installation file makes it possible to access it locally. The online help section is available here.
Management of security user accounts and groups in Enterprise Architect 12.1 has been improved with the Active Directory Groups support (prior to this version, each AD user had to be imported).
Tagged Values support in the Traceability view
The traceability view provides a dynamic, navigable view of the current element's relationships to other elements in the model, e.g. to find associated classes, realized requirements, etc.
Enterprise Architect 12.1 adds a support for model elements referenced in a Tagged Value. To illustrate this enhancement, a RefGUID Tagged Value (see. Sparx EA User Guide) has been defined so that a reference between an business and implementation class can be set. In the example below, the traceability view shows a link between Class1 (Domain Object) and Class1 (System) via the "Tagged Value References" list.
Metafile rendering improvement
Image Metafile rendering has been improved with Enterprise Architect 12.1. An anti-aliasing filter is applied for many metafiles to increase the image clearness. Below is a screenshot-based comparison between Enterprise Architect versions 12 (build 1512) and 12.1 (build 1220).
Capture écran EA 12
Note: a new image library to use with Enterprise Architect 12 is available from Sparx Systems web site.
The Quicklinker is a very useful feature that lets you create elements on the fly from within a diagram. Enterprise Architect 12.1 makes it possible to create multiple elements at once. When dragging the Quicklinker, a new option is available:
The Model Wizard is available via the Project Browser to create a predefined model structure, provided by Sparx Systems. A new "Customize Pattern on Import" option is available to let users select the model branches to generate.
Enterprise Architect 12.1 introduces the concept of virtualized elements, a feature that lets you show several times the same element onto a diagram. This feature answers a need for a number of users that need to achieve this e.g. to simplify its layout.
Once a connector has been created between elements, a right click on this connector makes it possible to create a virtual representation of the element. In the following diagram, a blue connector has been added between the Transaction and ShoppingBasket classes.
  • Enterprise Architect 12.1 does not let you create connectors to a virtualized element. It would be useful as an enhancement to allow the association of a virtualized element with any other element.
  • When the element or any of its virtualized version is selected, they’re all selected.
  • When the main element is hidden, all virtualized elements are hidden as well since they're directly associated with connectors.
  • Hiding a virtualized element will hide the connector as well.
  • Virtualized elements don't count as additional occurrences of the element in the diagram (results from running Find in All Diagrams are the same).
This feature hasn’t changed for a while until this new version 12.1 which supports a link between the diagram legend and the rendering style of the elements and connectors.
The Diagram Legend window provides additional options to compare elements with the legend’s content. If an element matches a set of criteria, it will be rendered with a fill colour, line colour and line width as set in the legend’s value. This is enabled with the “Apply auto color” option.
To test this enhancement, a filter has been defined on the element’s alias i.e. the legend’s values will be compared with the elements’ aliases. Evaluation has been restricted to Class elements (see option "Applies to" in the screenshot below). On the following diagram:
  • StockItem class is rendered in green as its alias is set to 1
  • LineItem class is rendered in light red as its alias is set to 2
  • Class2 class is rendered in light blue as its alias is set to Class (note that Class1 alias doesn’t match)
  • In a given legend, I can only apply a filter for a specific type of elements. In other words it is not possible to define styles for classes, interfaces, and components in a diagram. A diagram legend definition is also restricted to a given element’s property such as the alias (note the element’s name doesn’t seem to be supported). It would make more sense to make the Filter and Applies to settings specific to each diagram legend value.
  • Matching values only work with numeric values or identical string values. It would help to have a way to set a rule like ‘Class-*’.
  • It would also be useful to have an option to define a connector’s line style based on the legend (e.g. Orthogonal, Tree Style...).
  • The tested value is shown in the legend whereas in most cases it is not relevant to the target audience. It would be better to have a separate field to set the content to display in the diagram legend, e.g. to display "Customer" for elements matching the rule where their Alias starts with "Cust-", instead of showing "Cust-" in the legend.
According to Sparx Systems, Info View is a new option aimed at providing “a simplified view of an element that allows the name, description and selected other properties to be displayed […]. This view allows a diagram to be constructed for a non-technical audience or any purpose where display of descriptions is more important than the notations defined by the modeling language.”
This can be enabled via a right click on an element > Info View > Enabled. Then properties can be chosen as needed. Below is an illustration for a class and use case:
Wireframing has been introduced in version 12 to create UI diagrams for web sites, iPhone, iPad and Android phones. Windows Phone support has been added in Enterprise Architect 12.1:
  • CIM Schemas can be reverse-engineered to create Schema Composer profiles.
  • When loading classes into the Schema Composer from Message Assemblies or from Class Diagrams, all classes referenced through inheritance and associations are also loaded, ensuring the inclusion of all classes required for generation of valid schemas.
  • Multiplicity is shown for SysML 1.2 and 1.3 ports displayed in a compartment on their parent block.
  • On Parametric diagrams, SysML 1.3 Properties owned by constraint blocks or constraint properties are now drawn as a small box with an external label.
  • The ID and Text values of SysML requirements can now be displayed in the Summary window.
  • Behaviour of copies of SysML requirements updated such that Text tagged value on copies is pinned and updated as the original is updated.
Sparx Systems has announced the following: “Enterprise Architect supports BPSim, a specification for parameterization and exchange of process analysis data, allowing the creation, comparison and reuse of different simulation configurations stored within the model. BPSim takes into account a wide range of runtime information such as statistical information, random variations, queuing, scheduling and resources. BPSim configurations can be exported from Enterprise Architect for consumption in a 3rd party simulation engine”.
BPSim Enterprise Architect 12.1 business process simulation
