Displaying items by tag: database engineering
A few months ago, we released the Parallel Agile Add-in for Enterprise Architect. This add-in gives Enterprise Architect users a unique opportunity to save substantial amounts of time in building the database infrastructure for your project, because you can now generate it automatically from a domain model (class diagram). What gets generated includes database access functions, an API to access the database, API documentation of, and some client side code that shows you how to call the API - what we're calling an Executable Architecture. Our first target platform is MongoDB and Node.JS (aka MEAN Stack), but we're currently working on additional platforms including MySQL and Firebase, so stay tuned.
First, you would need to build the basic set of database access functions for each database collection (or table) that you’re going to need. These are the CRUD (Create, Read, Update, Delete functions). In a NoSQL database like Mongo these are implemented with GET / PUT / POST methods:
Next, you would need to define a REST API to allow your client-side code to call the database access functions. In a MEAN Stack application these are bundled together in an Express JS file as shown above. Note that each of your database access functions has several layers of exception handling that need to be built.
Once your API is in place and documented, you’ll want to write some client side code that encapsulates the database access methods. You might write a JavaScript client that handles callbacks:
All of this code is infrastructure for your project, and tends to be of a somewhat boring and repetitive nature - you always need to write the database access functions, they need to be written for each collection, and the code is all very similar to the code you wrote yesterday. Writing it by hand is slow, tedious, and error-prone.
Yet in thousands of development organizations around the globe, developers are writing the database access layer of their applications manually. We asked ourselves if there was a better way and decided the answer was yes. And then we built it. If you’d like to try it, download the free Parallel Agile Add-In for Enterprise Architect.
Introduction to the Database Builder
Enterprise Architect’s Database Builder provides interactive connectivity to a DBMS, supporting both the initial creation of a database and the ongoing update of tables, views, triggers and procedures – all from within the design model.
This tutorial paper works through a simple database example (attached in .ZIP file) using the Database Builder to create tables within a new Database, then make modifications in both the model and the Database and use the compare functionality to update the Database and the model respectively.
Database Engineering with Enterprise Architect 12
Enterprise Architect includes a powerful new database engineering toolset. The new Database Builder greatly enhances Enterprise Architect's existing data modeling capabilities – making it easier than ever to model, generate and synchronize database designs.
In this webinar you will learn how to:
- Model a database from scratch using predefined patterns
- Connect to live databases, run queries and compare differences
- Synchronize your live database schema based on model changes
For more information:
To view the entire webinar series:
http://www.sparxsystems.com/resources/webinar/webinar-series.html
Click the link below to register:
