Displaying items by tag: database modeling
How easy is it to generate a working database and API from an EA domain model? Really, really easy...
This video will show you how in less than 3 minutes…which is about how long it takes for you to try it yourself. In our example, your app can show video of the players scoring touchdowns in near real-time
Introduction to the Database Builder
Enterprise Architect’s Database Builder provides interactive connectivity to a DBMS, supporting both the initial creation of a database and the ongoing update of tables, views, triggers and procedures – all from within the design model.
This tutorial paper works through a simple database example (attached in .ZIP file) using the Database Builder to create tables within a new Database, then make modifications in both the model and the Database and use the compare functionality to update the Database and the model respectively.
