Displaying items by tag: roundtrip engineering
Debug Model & Code side by side
There are a number of techniques available that allow code generation from a UML model. Learn how to debug the modeled behavior using both UML and the generated code.
The following video shows the first integration between the modeling environment: Enterprise Architect (Sparx Systems) and the embedded IDE: MULTI (Green Hills). In the video the uml2code C-code generator (LieberLieber) is used.
The code will be generated directly from the UML model, copied into an existing MULTI-Project, compiled and deployed in a virtual hardware simulator. This ensures that the system can be debugged simultaneously via the code and using the UML.
For more information, please visit: www.lieberlieber.com
