Displaying items by tag: code analyzer
- The Code Analyzer is a must-have tool when working with source code. It runs extremely complex queries on source code repositories at incredible speeds, when used locally or on a Sparx Intel cloud service.
- The Code analyzer uses a high-level query language developed by Sparx systems. It also has a large vocabulary that allows code metrics to be queried quicker than traditional methods.
- It is highly effective for large-scale code bases. This is because it allows the user to rigorously check any minor changes using a distinct cross-reference analysis of the code to verify that all effects are clearly visible.
Code Miner Framework
- In Sparx Enterprise Architect 16, users can compile their code base into a Code Miner repository. Code Miner system provides instant and comprehensive access to existing source code information.
- It enables complete access to all features of the original source code in a machine-readable manner. This is done by parsing all source code and storing the resulting “Abstract Syntax Tree” in a read-optimized database.
- The main purpose of the Code miner is to give quick and effective access to data concealed within source code.
- The interfaces have been designed to be as simple as possible while ensuring optimal performance.
- As a result, the system can assess the program's structure, calculate metrics, track relationships, and even refactor the code.
Figure 1: Code Miner Framework
What’s New in Sparx Enterprise Architect 16?
Sparx Intel Service
- The Sparx Intel service program enables development projects and customers to learn more about the code bases and software frameworks they're working with.
- Multiple Enterprise Architect customers can use the service to access and (raise a query for the same data) query the same data from a variety of software domains and frameworks.
- Clients of Enterprise Architect can use the service to have access to Intelli-sense in code editing and smart search results in search tools.
- The Sparx Intel service is a division of Sparx Satellite Services. The service can be installed on a local network or in cloud, plus it runs on Microsoft Windows.
- The Sparx Intel Satellite service can be executed as a standalone process or as a Windows service.
Figure 2: Sparx Intel Service
Config File Format
| Directive | Description |
| Name | When a service is named on the command line, the service with the matching name attribute will be commence. |
| Status | The service will be start only when status = ON |
| Lazyload | When lazyload is 'true', any Code Miner database will be delay loaded until an Intel request is made to the service. |
| Loglevel |
Defines the level of information logged, as a combination of keywords { information, warning, error} separated by a '|'. For example: loglevel= Information|warning|error |
| Logoutput |
Specifies the full pathname of the log file to write to. For example: logoutput=c:\logfiles\intel-service-project1.log |
| Database |
Specifies the full path name of the Code Miner database to be loaded. For example: database=c:\intel--service\project1.cdb Multiple 'database' directives are allowed, each specifying a different database. |
| Allow |
Identifies the IP address that is permitted to connect to the service on the Port. For example: allow=localhost allow=127.0.0.1 allow=172.160.* (wildcards are allowed when the 'network' directive has a value of 'network' or 'public', but not 'local') |
| Network |
Allows service connections to be restricted.
| Show | When 'true', the Console window for the service will be shown; the default is 'false'. |
| Port | The Port on which the service will be heard |
Please contact us or write an email to This email address is being protected from spambots. You nedd JavaScript enabled to view it. or call us @+91 8248004261 to have a live demo about the new EA 16 features and capabilities.
Click here to see a sneak peak of how Code Analyzer in EA16 works.
