Displaying items by tag: sparx ea16
  • The Code Analyzer is a must-have tool when working with source code. It runs extremely complex queries on source code repositories at incredible speeds, when used locally or on a Sparx Intel cloud service.
  • The Code analyzer uses a high-level query language developed by Sparx systems. It also has a large vocabulary that allows code metrics to be queried quicker than traditional methods.
  • It is highly effective for large-scale code bases. This is because it allows the user to rigorously check any minor changes using a distinct cross-reference analysis of the code to verify that all effects are clearly visible.
Code Miner Framework
  • In Sparx Enterprise Architect 16, users can compile their code base into a Code Miner repository. Code Miner system provides instant and comprehensive access to existing source code information.
  • It enables complete access to all features of the original source code in a machine-readable manner. This is done by parsing all source code and storing the resulting “Abstract Syntax Tree” in a read-optimized database.
  • The main purpose of the Code miner is to give quick and effective access to data concealed within source code.
  • The interfaces have been designed to be as simple as possible while ensuring optimal performance.
  • As a result, the system can assess the program's structure, calculate metrics, track relationships, and even refactor the code.
Code_Miner_Framework
        Figure 1: Code Miner Framework
What’s New in Sparx Enterprise Architect 16?
Sparx Intel Service
  • The Sparx Intel service program enables development projects and customers to learn more about the code bases and software frameworks they're working with.
  • Multiple Enterprise Architect customers can use the service to access and (raise a query for the same data) query the same data from a variety of software domains and frameworks.
  • Clients of Enterprise Architect can use the service to have access to Intelli-sense in code editing and smart search results in search tools.
  • The Sparx Intel service is a division of Sparx Satellite Services. The service can be installed on a local network or in cloud, plus it runs on Microsoft Windows.
  • The Sparx Intel Satellite service can be executed as a standalone process or as a Windows service.
Sparx Intel Service
        Figure 2: Sparx Intel Service
Config File Format
Directive Description
Name When a service is named on the command line, the service with the matching name attribute will be commence.
Status The service will be start only when status = ON
Lazyload When lazyload is 'true', any Code Miner database will be delay loaded until an Intel request is made to the service.
Loglevel
Defines the level of information logged, as a combination of keywords { information, warning, error} separated by a '|'.  For example:
     loglevel= Information|warning|error
Logoutput
Specifies the full pathname of the log file to write to. For example:
     logoutput=c:\logfiles\intel-service-project1.log
Database
Specifies the full path name of the Code Miner database to be loaded. For example:
     database=c:\intel--service\project1.cdb
Multiple 'database' directives are allowed, each specifying a different database.
Allow
Identifies the IP address that is permitted to connect to the service on the Port. For example:
     allow=localhost
     allow=127.0.0.1
     allow=172.160.*      (wildcards are allowed when the 'network'
                                      directive has a value of 'network' or 'public',
                                      but not 'local')
Network
Allows service connections to be restricted.
  • local - the service can’t be heard on any connection other than localhost
  • network - when used with wildcard 'allow' directives, it allows clients on an allowed IP address wild card to connect
pubic - allows any connection
Show When 'true', the Console window for the service will be shown; the default is 'false'.
Port The Port on which the service will be heard
Please contact us or write an email to This email address is being protected from spambots. You nedd JavaScript enabled to view it. or call us @+91 8248004261 to have a live demo about the new EA 16 features and capabilities.
Click here to see a sneak peak of how Code Analyzer in EA16 works.
Wednesday, 25 May 2022 04:08
  • Ribbon: Design > Package > Gantt View
  • Ribbon: Design > Diagram > Views > Gantt View
  • Diagram Context Menu:  Switch View | Switch to Gantt View
  • Browser window Package context Menu | Open Package in | Gantt View
  • The users can get a clear picture of what’s going on with any element.
  • Drag and drop to quickly change the start and end dates.
  • It’s simple to add and change tasks.
  • On work items, the user can zoom in and out.
  • For rapid visual reference, percent completion is placed on tasks.
GANTT
 Options  Actions
Display tasks only for ‘today’ or ‘another day’ Right-click on the display and select the option:
  • 'Show Only Active Tasks for Today' - to show only tasks that are in progress today
  • 'Show Only Active Tasks for Other Days'—to show only tasks that were in progress on a specific day in the past, or that are scheduled to be in progress on a day in the future; a calendar dialog displays from which you select the day to examine
Display the properties of the element to which a resource is assigned. Right-click on the element entry and select the 'Show Element Properties' option.
The 'Properties' dialog for the element displays.
Display the Resource Allocation details for an element or resource. Right-click on the entry and select the 'Show Task Properties' option.
The 'Assigned Resources' dialog gets displayed. You can now edit the details and, if necessary, change the resource allocated to the element.
Display the Resource Allocation records for an element. (Also available in the Report View.) Right-click on the entry and select either of the context menu options:
  • 'Show Element Resource Allocation window' (if the window is closed or hidden)
  • 'Find Task in Element Resource Allocation window' (if the window is visible but showing the details of another element)
The Resource Allocation window displays the details of the selected entry  and other resource allocations for the element listed in the left-hand panel.
You can edit the details and, if necessary, change the resource allocated to the element.
Assign a new resource to an element. Right-click on an element in the display, and select the 'Assign Resource' option.
Please contact us or write an email to This email address is being protected from spambots. You need JavaScript enabled to view it. or call us @+91 8248004261 to have a live demo about the new EA 16 features and capabilities.
Custom Documentation
  • Sparx Systems Enterprise Architect has a powerful feature to generate a quick report through the ‘Custom Document’ feature.
  • Beneficial among businesses and firms not only because of the ease of generating reports but also because they are usually quite accurate and uniform.
  • Helps the business to stay competitive by making the right data available to the right people at the right time.
What’s new in Custom Documentation in Sparx Enterprise Architect 16?
  • New custom document templates and sample document contents are available through Model Wizard and can be accessed from Document Publishing perspective.
  • This new documents templates allow you to produce high level design, functional and business requirement document.
  • Creating a Custom Document is fairly simple, and you can generate a document with a few clicks by simply dragging and dropping a model content from the Project Browser.
  • It Dynamically updates the entire document or a particular section, ensuring that it reflects the latest changes in the Model. So that, you can save time and avoid regenerating a document then copy-paste the changes in the existing word documents.
  • Warnings are now displayed when data is lost when updating a dynamic part.
  • Ad hoc reporting features allow users to customize to insert their own words, images, logo and other contents to their own requirements.
  • Improved content list, which now includes the element and template for each dynamic part.
  • During document generation, a progress indicator will bring better feedback.
  • Numerous improvements and usability improvements have been made.
Custom Template Figure 1: Custom Templates
Please contact us or write an email to mailto:This email address is being protected from spambots. You need JavaScript enabled to view it. or call us @ +91 8248004261 to have a live demo about the new EA 16 features and capabilities.
Click here to see a sneak peak of how Auto Refresh in EA16 works.
